Hello. i am having a problem figuring out how to make my components all work together. I just got a 37" x 31" eliptical dish with 6 lnbs and all kinds of brackets to mount the lnbs wherever i need to. Now that I have this huge dish going up on my new house, I need to figure out how to make it work with my system. I have 5 TV's. each one has a vs ultra and a dish sub. that way I can watch either one simply by using video 1 or 2 on the TV's. I have 2 cables running from where the switches go, to each TV. I have 4lnbs on the dish 82, 91, 110 and 119. I can run as many cables from the dish as necessary. I need to figure out how I can get away without putting up another dish for the subs. I thought of a few possibilities.
1- Get a huge switch to handle everything. 8 in and 10 out. but I have not seen any switches that will make this all work with no bugs.
2- Somehow split the cables coming from 110 and 119 so I can feed an emp 9x8 for the ultras, and feed some other switches for the subs. I don't know how this would be possible but maybe you do.
3- I don't even know if they exist but get some kind of single lnbs with 4
outputs for 110 and 119. 2 horizontal and 2 vertical. that way I can bring 2 cables from each to an emp 9x8 for the fta and bring the other 2 from each lnb to some other switches for the subs.
I am open to ideas of how to make this all work. I guess the bottom line is I only want one dish, I don't care how many lnbs are on it. I don't care how many cables I need to run to my switches, I don't care how many switches I need, I need to have 5 fta receivers on 82, 91, 110 and 119, I need to have 5 subs on 110 and 119, I need to be able to have all 10 receivers on and working at the same time.
If you have any ideas of how to do this please let me know. thanks
