I got a Digipower SG-2100 with a 50mm motor tube. Is there a special trick to getting this replacement motor tube to fit? I have the original tube off but the replacement tube doesn't line up enough to where I can get the bolt back through it.
Yeah stupid question. For $13 what should I expect right. I will just drill the hole in the tube just a little bit bigger tomorrow and hope all is good after that.
I did notice that I did that this morning. I am about to go out and give it a go. I will post back once I find out.![]()
Yeah I think I am finding that out. Are you talking about the angle iron or the mount I robbed from the directv dish? I think I might run down to home depot and get some pvc and use original mount if I completely fail with this setup.
Limited time offer
