97 G25 it used to be IA5 & T5
try looking it up as one of those
i can't remember but i think the traxis 1500 you can't edit the satellite names ( there should be a thread here on it somewhere)
if the receiver won't let you modify satellite data then it unlikely you can change it
you can try to modify the satellite names or satellite locations with the remote thru the menu. but it sounds like the receiver isn't updatable unles DMSI or the folks that make traxis updat the file for you.
