DishNetwork Uplink Activity Report - 5/13/2008 11:08pm - Last 5 VOOMs removed | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/17/2008 - 16 changes
Uplink Comparison Range: 05/13/2008 08:52P - 05/13/2008 11:07P
Channel Removals:
9471 - EQUTR (A) removed from EchoStar3 61.5W TP 20 ConUS beam
9471 - EQUTR (A) removed from EchoStar5 129W TP 23 ConUS beam
9472 - HD (A) removed from EchoStar3 61.5W TP 10 ConUS beam
9472 - HD (A) removed from EchoStar5 129W TP 17 ConUS beam
9476 - RUSH (A) removed from Echostar12 61.5W TP 24 ConUS beam
9476 - RUSH (A) removed from EchoStar5 129W TP 22 ConUS beam
9479 - KNGFU (A) removed from Echostar12 61.5W TP 24 ConUS beam
9479 - KNGFU (A) removed from EchoStar5 129W TP 22 ConUS beam
9481 - MNSTR (A) removed from EchoStar3 61.5W TP 20 ConUS beam
9481 - MNSTR (A) removed from EchoStar5 129W TP 23 ConUS beam
Miscellaneous:
9470 - RAVE EchoStar3 61.5W TP 20 ConUS beam MPEG4 HD changed to HD - EchoStar3 61.5W TP 10 ConUS beam MPEG4 SD
9470 - RAVE EchoStar5 129W TP 23 ConUS beam MPEG4 HD changed to HD - EchoStar5 129W TP 17 ConUS beam MPEG4 SD
Transponder Changes:
Echostar12 61.5W TP 24 ConUS beam 8PSK removed from tables
EchoStar3 61.5W TP 20 ConUS beam 8PSK removed from tables
EchoStar5 129W TP 22 ConUS beam 8PSK removed from tables
EchoStar5 129W TP 23 ConUS beam 8PSK removed from tables
Channels in the system: 5054
(A) = Available to subscribers
(NA) = Not Available
Just an FYI... the video streams and transponders are still active. The simply removed the channels from the tables so your receiver no longer sees them.
It will be interesting to see how long they will hang around. Would this just be a tactic by Dish to put pressure on Voom to get what they want?
Wanna see full tables in your PM ? I think your algo have a bug ;).
BTW, they make other sign - the version wasn't in order: last at 5pm PDT was #24, they skip #25 and this last one have #26 !
Shouldn't this be called an "unlink" report?
Voom did this to themselves. They lied and didn't spend the money on making content. They had a golden goose in DISH that took them from tens of thousands of subscribers to literally millions and then they just sat on their thumbs. They could have been something real good eventually, but they took for granted what DISH gave them and pushed themselves towards irrelevance.
I sure hope so. I just registered my disappointment with a chat representative who apologized when I pointed out that 22-15=7.
Damn, I had a bunch of movies set to record. Why get rid of the Voom channels if you aren't going to put anything in their place?
By the way, those two "slates" are now running a loop bragging about their new 22 channels and promising 100 by the end of the year.
I wonder where I've seen that satellite with all the TV pictures on it before...?
interesting note: I just dvr'ed a minute of it; the event is titled "Montreux Jazz Festival 1997" - leftovers in the epg, I guess.
Uplink Activity 5/12/08 11:55 PM EDT 10 VOOMs gone.
D
DishNetwork Uplink Activity Report - 5/21/2008 12:03pm - 2 changes
