I could have sworn that I had WGN-HD a few weeks ago (around the time Dish turned on SciFi and USA), but it doesn't show up anywhere now. Was I dreaming or something?![]()
If Dish Network adds WGN-HD, does that mean that essentially Dish will have CW in HD? Or would this NOT be the "version" of WGN that shows CW programming.
No, we're talking about the Superstation. They might turn it on in the next few weeks, a.k.a. soon.![]()
It is uplinked on 129 currently. It will be on 5379/9446. It is WGN Superstation and not the real Channel 9.
Quick question: I'm sure that KTLA, KWGN, etc.. are available to DISH subscribers in those areas as HD. So does anyone know why none of Superstations are uplinked to the rest of the subscribers in HD format? They obviously already have them on the satellite.. wouldn't it just be a difference of what they call them (wether I get the "Superstation KTLA" or the "regular KTLA".. which you say are exactly the same).
Dish does not carry KTLA in HD here in LA. In fact, they are the only provider that doesn't. Direct, FiOS, and all of the local cables company carry KTLA HD.Quick question: I'm sure that KTLA, KWGN, etc.. are available to DISH subscribers in those areas as HD. So does anyone know why none of Superstations are uplinked to the rest of the subscribers in HD format? They obviously already have them on the satellite.. wouldn't it just be a difference of what they call them (wether I get the "Superstation KTLA" or the "regular KTLA".. which you say are exactly the same).
This would make my year if E* makes WGN TV 9 HD available to Chicago local subscribers. I would take back all of the bad things I said about them... Ok, maybe not all, but at least half of them!WGN TV 9 Chicago is currently uplinked BUT NOT AVAILABLE on channel 5085 on tp 11 spot 14 at 61.5º
This is along side the rest of the Chicago local network HD channels.
Limited time offer
