Coming from an E* 622, which never turns off, what is the answer? Will the HR-21 miss a timer event if it is turned off?
Many things work better when the receiver has some down time to process them.
This is why I called the state "down time" as opposed to "off". Off implies that no processing can be done.As mentioned above, when you turn it off, it goes into Stand By, not OFF.
Because it's not really off. It's really in standby.why does it still make a noise when its turned off ?
The lights on the front go out and the outputs go off.
It is still recieving/buffering the signal.
However, when it's in standby/off it knows you aren't watching TV. It can then do it's system maintenance.
Mike
I guess....oh ok.... so the plain hd receiver (no dvr in it) didnt because there was no buffer etc.
The drive is probably still spinning during 'sleep', so even if the fan is not on, you might hear the drive.
Yep you pay for them 24/7 with your power bill. I just got one of those power use detectors but I haven't pluged the HD DVRs into it yet to see how much power they use. I'll let you'all know by the weekend.
Limited time offer
