I know you guys are out there...it was a tongue-and-cheek comment.I still have a Guide+ TV. I figured why upgrade to a HDTV when there is no HD in my area.If so then you would be getting the same thing.
I about had a melt-down, 'till I read the whole story.Cnet Review said:Video quality was fairly good overall, but a notch below the best converter boxes we've tested. We compared it head-to-head with the Zenith DTT900 using the composite video input, and we found the DTVPal to be a tad softer, with more jaggies and other image imperfections. It was nearly as bad as the GE 22730, and more comparable to the image quality of the RCA DTA800. We noticed these differences on an HDTV--where the quality differences are more pronounced--so users of standard analog TVs will notice fewer differences.
Thanks Wolf!Sorry to hear about your wife.
My wife is not really good at technical things and all the remotes she had to use to change from TV to DVD etc just drove her up the wall.
So I went out and bought a Harmony 880 remote.
You set this thing up through a web site and it has setting like watch TV, watch DVD etc. It works really good and I bought it on Amazon for about $100.00.
You don't have to do any thinking to use it.
Just a thought.
Yes, I agree the "substitute zip code" you must enter into the "Guide device" must play a role in limiting the Guide listings to OTA channels, whether the analog TVGOS data is generated from PSIP or converted from digital TVGOS. It's too bad the list of zip codes on page 28 wasn't included in the pdf. It's probably just a page full of numbers, but it would have been another clue for me. (I thought the vast majority of possible zip codes were in use. How many "substitute" ones could they come up with?)Guy, thanks for the update!
it is still possible that the only guide information being provided to the TVGOS device are for the local over-the-air digital channels. Note the "Substitute ZIP Codes" which are listed on page 28 of the User's Guide. This implementation doesn't make a lot of sense since the DTV Pal will still be providing a conversion process of the PSIP datastream, and the GemStar TVGOS folks would have to support the Substitute Zipcodes. Why not just implement DVS-706 conversion and be done with it?
My hunch is the DTV Pal is providing a PSIP to analog TVGOS conversion for the local digital channels, and the substitute zipcode supports how the information is being presented from the DTV Pal (i.e. channel mapping, etc.).
We Sony HD DVR folks are a vocal/techie group, but our numbers are certainly quite small overall. Additionally, as I previously mentioned there are only a dozen or so CBS O&Os currently broadcasting digital TVGOS. I would love to test the DTV Pal and see if it actually supports digital-to-analog TVGOS since I have a CBS O&O in my area.
Where can I purchase one of these Dish digital converters for $59.00? In PUerto Rico stores cannot keep up with demand ..They are selling like hotcakes ...please somebody tell me where I can buy this item on the web !! Send me A private IM .....THANKS in ADVANCE ,
I've been cleared to give away my DTVPal. If you want it prior to release, enter here:
The DTVPal Giveaway
Limited time offer
