Hello all, I have a Pansat 9200 HD in my den, with 4 way diseqc switch (4 dishes) . I wanted to put my old Pansat 2500a in the bedroom for just G10r/18. Should I connect it from the 9200's IF out, or put a dual output LNBF on my G10r dish? Thanks!
No.Will any voltage from the added receiver "leak through" the dual LNB, back up the other cable, to the diseqc switch for the system in the den?
...And will the receiver in the bedroom be able to select polarity independently?
Here's a picture of such an LNB bolted onto a Primestar (?) feedhorn. (picture credit: unknown, probably on SatGuy's)
Here's a different style feedhorn from a Channelmaster (?) dish, with a Norsat LNB , but the bandstacked from the picture above will bolt right on (picture credit to: Tron).
Limited time offer
