DIRECTV Remains Clear HD Leader with 130 HD Channels | Page 23 | SatelliteGuys.US
Newly mapped HD channel numbers. The stations are now being tested in their proper number and off of the 9xxx test channels.
TEST, 144, 12, 1040 (PPV)
TEST, 163, 4, 1020 (PPV)
TEST, 181, 6, 1020 (PPV)
TEST, 311, 3, 1040 (ABC Family)
TEST, 683, 2, 1030 (FSNRM)
TEST, 659, 4, 1050 (FSNPI)
TEST, 649, 6, 1010 (Sports South)
TEST, 668, 11, 1020 (FSNNorth)
TEST, 686, 1, 1030 (FSN Arizona)
TEST, 647, 11, 1010 (FSNMW)
TEST, 541, 5, 1020 (Showcase)
TEST, 286, 7, 1030 (Planet Green)
TEST, 687, 9, 1050 (FSNNW)
TEST, 653, 10, 1030 (Sun Sports)
TEST, 660, 14, 1010 (FSNOH)
TEST, 654, 8, 1040 (FSNFL)
TEST, 661, 5, 1040 (FSNCN)
TEST, 646, 13, 1050 (FSNSouth)
TEST, 542, 14, 1030 (Show Extreme)
TEST, 150, 14, 1020 (PPV)
TEST, 164, 6, 1030 (PPV)
TEST, 165, 10, 1040 (PPV)
TEST, 180, 6, 1040 (PPV)
TEST, 182, 4, 1040 (PPV)
This makes 8 new PPVs
They have also moved many of the current PPVs off of D10 to D11 (not shown here).
Thanks again to P Smith...:up
8 PPVs + 12 RSNs + 4 new channels = 24
Even without removing any PPV that still leaves 11 more slots to make 35. They can put up much more than 35.
14 CONUS I believe. D* current pattern has been no more that 5 per TP. So that would mean 70 CONUS channels from D11.
21 legacy moved from D10 to D11, including PPV + 12 new RSNs + 8 new PPV (some may be temporary) + 4 new stations = 45 total. Yes they can get another 30 or so station on D11.
This also frees up space on D10. The pattern appears as if they want to put all of the RSNs and PPV with other nationals on D11 and all of the premiums and other nationals on D10. This is just the trend of movement in the last few days...nothing official.
Who holds the licences for the other 18 at the 99 D* Spaceway 2?
It's not the satellite that has the licenses for a particular orbital postion its the company, as in D* or E*, if they decided to use 1 or more satellites to provide all their licensed coverage that's up to them. In the case of 99 and 103 Ka licenses if you read the link I gave you earlier in this post: DBSTalk.Com - View Single Post - DIRECTV and Ka (with satellite configs) Tom says:
"Typical Ka dbs licenses allow two 500 mhz ranges of downlinking: 19.7-20.2 GHz (A-band) and 18.3-18.8GHz (B-band) as well as three more of uplinking. Ku licenses allow one 500 mhz range each.
Directv standard Ku transponders, numbered 1-32, are 29mhz wide with 24mhz usable. For D10 and D11, Ka transponders are numbered 1-24, and are 40mhz wide with 36mhz usable. S1 and S2 can be operated as eight transponders 62.5mhz wide."
DirecTV has the Ka DBS liceense for both 99 and 103 which they're using for the MPEG4 HD system, they also have a Ka license at 101 which they are using for backhaul purposes.
541 is not listed in the guide and it is not available yet, so I don't know.
Either they have a channel mapped wrong currently or it is a new Showtime channel. Showtime is supposed to add 8 HD channels in August.
Showtime to Add 8 HD Channels In August
Showtime says it will add eight new High-Definition channels in August, bringing its overall HD channel total to 12.
That's according to an article by Multichannel News.
Showtime officials also tell Multichannel News that it will add another 10 high-def channels by the first quarter of 2009.
Right we know they have 32 on each, But are they all Licenced? By looking at the number of N/A Transponders ,my guess is No.
I don't know. Some maybe outside of the broadcasting frequency range to be used for other things in the future?
Installation Question
RV
