Error Screen | SatelliteGuys.US
Error Screen
Y2k06
SatelliteGuys Guru
123
Why am I getting this screen more and more often? There are NO storms within 100 miles of here. It does it on Locals - just screwed up some Olympic Coverage:( This happened several times over the last few days. Other channels (non-locals) seem to be OK
I can go to OTA and get it fine....
This screen seems to appear when there is a loss of signal from the dish suppling the locals, I went to peak my 61.5 dish and as I moved the dish away from the sat this screen appeared as I brought the dish back the normal video came back, perhaps your dish need to be peaked.
Which one? 110, 119, or 129? They were just out here less than a month ago replacing all the LNB's due to 'drift' exceeding 9.
Check Switch and Signal strength all look fine... or as best as it's been with Zero Drift.....
I believe that screen originates with dish on the ground and indicates their link to the station has been interrupted.
Remote schedling progress?
Newer version of the 722?
