I also think this BluRay thing is nothing but BS. I don't have a BluRay player or own any HD or BluRay discs.
Then quit complaining about not being able to get a 1080p24 download from Dish. Watch the 1080i version.
A 1080p TV does not mean it will accept a 1080p signal, what it really means is the end result you see will be a 1080p video, whatever the incoming signal will be upscaled by the TV to 1080p.
So if the TV does not support 1080p/24, there is really no benefit of trying to force it to get the signal, the 1080i version of the HDVOD will be just fine, as long as your TV has the 3:2 pull down, then what you end up seeing will be the same as watching on a TV that can accept the 1080p/24 native signal.
I am not even sure which way is better, because in the later case the 722 will be doing all the scaling for the TV, and in the earlier case your TV will do all the scaling. If your TV does a better job than the 722 on the scaling, in theory you may get to see a better picture, that is if your TV is a good quality set with good 3:2 pull down. Personally I don't see there any difference that most people can detect anyway. In all practicality, you should get a Bluray quality picture just as if you are watching from a Bluray DVD box on your TV.
The only benefit in this case is the 1080p movie can be ordered for $2.99. I would not have ordered it had it been $6.99.
It's cheaper than a Blu-ray which sells for anywhere from $20 - 35.
Yeah, but with Blu-ray you can keep the movie forever. With VOD, you only keep it for 24 hrs.
...The output @ 1080i60 becomes 1080p60. 60/24 = 2.5. ...
You completely ignored something else I said: 3:2 pull down. A good 1080p set will do the 3:2 pull down to address the judder.
The benefit of a 120Hz set to me is the reduced eye strain.
3:2 pulldown doesn't address judder, it's the method by which you reassemble the original frames. They will still be in a 3:2 cadence at the end which means you'll still have judder.
On a 120Hz display, it could run 5:5 on 24p inputs and 4:4 on 60i inputs without judder.
Guess I should have used term "reverse 3:2 pulldown" or "3:2 pulldown detection" to describe how a good quality 1080p set with "3:2 pulldown" can really do to improve a video that originated from a film material after a 3:2 pulldown process. The reverse 3:2 pulldown is explained by the Projector People below, it referred to projectors but should apply to the 1080p HD sets as well:
"Why reverse 3:2 pulldown?
Reverse the process? Am I kidding? Sadly no. There are a few DVDs available that come as progressive scan rather than interlaced, but not many. When you consider the fact that the majority of people are watching DVDs on NTSC televisions and do not have the luxury of seeing them on the big screen from a front projector, it makes sense. It's okay to think about how much better our world would be if we all had giant progressive scan images from projectors in our homes, but it doesn't solve our problem. What does solve the problem is reverse 3:2 pulldown or de-interlacing.
'Reverse 3:2 pulldown' is the process of finding the original film frame. It would be easier to find the original frame if the new frames were not interlaced. However, as we mentioned before, we created extra video frames [through 3:2 pulldown], which are interlaced, by combining two different non-interlaced film frames. Simply displaying each video frame in progressive scan will create 'jaggies' and other distortion. Luckily, new progressive scan DVD players come with the de-interlacing built-in. Basically, the DVD player uses an MPEG decoder that knows which frames will create images with the least distortion and puts them together for you…
So in your quest for the best image for your money, what is the easy answer? Get yourself a progressive scan DVD player with 3:2 pulldown detection and use your projector's component input. You could spend the money on a projector with the reverse 3:2 pulldown (which is essentially what our 1080p sets with 3:2 pulldown are) as well, ..."
With a good 1080p set equipped with 3:2 pulldown detection, the judder issue should be resolved fairly well.
My SONY KDL-40V2500 1080P fails the test. What's the deal? Any updates on this?
I have the same model Sony, KDL 40V2500. Here is the bottom-line: I like Sony, don't have a Blu-Ray or HD DVD (or betamax), don't intend to get one and have been waiting for something like this TurboHD to come along.
The question I have is has anyone been told that we will enventually be able to get 1080p from DISH (that Sony 1080p sets can view)? That and when is really all I care about.
This entire thread has nothing but people pasting in info from the internet on what 1080p is. Then other people have gone off on a tangent trying to impress us with frame rates , etc.
So, will DISH make their signal Sony compatible? And when? I have talked to DISH techs 2 times and both times have been lied to.
I have a Sharp 1080p it will not work either. I think very few TV's do 1080p/24.
Limited time offer
