After several months of KU delight I am now about set to try out C-Band.
I plan to setup a dish at my parents place (which is only two blocks away from me) so they will be able to get C and KU FTA. Dad is fairly excited, mom does not care all that much. I hope to make it motorized, but if that don't work I'll set it up as a stationary for the time being.
It is not entirely a selfless act because I am over there practically everyday. Ah yes, great food and FTA TV at the same time.
Ok here is what I got so far on a next to nothing budget:
1: (A BUD) I helped some folks out with a computer tek problem and they had the BUD out in the back which they let me have for free.
2: (Cable) I found what looks like 100ft of new CATV 18 cable in a thrift store. That should work right? How does that compare to RG6 cable?
3: (Receiver Box) I got a Coolsat 6000 Premium on Ebay. It works perfectly.
4: (Motor Control) Hopefully it still works?
5: (Actuator Controller Box) It was in the garage and went with the dish. It is a TRACKER-IR Antenna Positioner - Satellite Locater by Houston Tracker Systems. It was made when I was in dippers, but it turns on and appears to work. So if the motor works, will I be able to just hook up the motor to it and rotate the dish by manually entering degrees?
The only thing I can think of that's left to get is the C/KU LNBF and an in-line amplifier.
I was planning to get a BSC-621 LNBF but I have read that the KU reception is not good.
So instead I am thinking about getting a CK-1 LNBF. Can anyone verify that the KU is better with this LNB? The BSC-621 appears to have the switch built into it so if I got a CK-1 instead would I also have to buy a separate DiSEqC Switch with it?
Here is the in-line amplifier I plan to get: ( signal booster )
Well what do you guys think? Will that do the trick?
And should I be able to have the dish rotate by using the old Controller Box or is there something I am missing?
I know in the long run I should get a GBOX but I just don't have the cash at the moment.
Thank for any help you guys can provide :up
