They both start with S19, but that's not what you mean, is it? Sys Info shows DNASP241 DshH02 on my ViP 211.Ask Foxbat about the numbers of his new purple G3 cards.You will see similarities.
Not a Trojan Rabbit?
So ,the next Question remains, Am I now ready for Eastern arc?
undisclosed, how did you extract that info, do we want to know?So far all ppl reported the new G3 (purple if external) have same IDs:
- DNASP 241
- Revision DshH02.
As to DTVPal/TR-40, the device carry undisclosed embedded smart card [DNASP 243, Revision DshH80] and Dish keep users in a dark regarding a purpose of it.
So if all goes well on October 8th I can buy the Dish 1000.4 and be good to go.YES !
The front panel may have come slightly loose.....remove the five screws (around the back and under the receiver).........pull the front panel off slowly by pressing the four plastic tabs at the front. Then put the card in the front panel slot, by opening the door, and push the panel back on, making sure that the card enters the beige colored card reader slot on the board......then screw back up and enjoy.Is it possible that my first receiver wasn't built correctly?? Maybe it doesn't have an internal card receiver(whatever its called).
Limited time offer
