Remote A/B Switch? | SatelliteGuys.US
Remote A/B Switch?
elder
426
5
I am at present using three antennas with two of them summed. I am using an amplified Antennas Direct XG91 for my hardest to receive station and am thinking a remote A/B switch located before the amplifier might be useful when I arrive at my final configuration. I have not been able to locate a suitable switch, any ideas out there?
Radio Shack sells a remote controlled A/B switch for $43.99.
Catalog # 15-1968
The 15-1968 uses an infrared remote, not RF, so it needs to be in the room with the entertainment gear. That implies two downleads from the antennas to the A/B switch at the entertainment center.
Kworld VS-ATSC-315U
HDTV Set For DXing??
