PowerVu receivers | Page 5 | SatelliteGuys.US
PowerVu receivers
There are a couple of Digitrans 7100/7150s out there on Fleabay, but they're a bit pricey. The 7150 is another option for DVB 4:2:2 as well as fixed and zero key DCII. The 7100 will get 4:2:0 DVB and DCII (no 4:2:2). Be sure you DON'T get the ASI only model (DTE-7150ASI), get the one with four standard LNB inputs. These are commercial, broadcast-grade receivers that are not in any way user-friendly, but they will work for these applications.
I work in TV and the place I work at has a D9850 that use to be used to get LeJournal feed and that was encrypted but the program provider had the S/N number for it. The other S/A is used for BBC World and that is encrypted too but that SA will get free to air channels too. You can only set up one transponder at a time and these units we have are rack mounted. Give yours a shot see what you can get Free or not. My 2 cents.
The 9850 has around 54 presets...use the network interface, it is easier to set up...you need to pay attention to the "lock on" setting...PAT or NIT....take your pick, it matters...:up
Perhaps someone can help me with my D9234 issue? Somehow, I've managed to get mine stuck in what is called the Download Decoder Status menu. I have no idea how I got there and now I can't get it out.
Any suggestions?
Factory reset or power cycle...:eureka
I can't get it to reset and a power cycle just starts the download decoder process all over again. Still not sure how it has defaulted to this menu on startup and can't exit out.
I sent Ice a URL that discusses this process and hopefully he can figure it out.
The receiver sat for over a year and was working fine. I've got good signal lock on G18, 11720 with a signal strength of 75 but nothing for quality.
What is the EXACT Front Panel display upon boot-up?
I've never heard of it doing that. I just powered mine up and it shows 0000 for channel. I had it on G10 as noted in this post
My 9234 has no display. It has a green LED for power on and another green LED when it has signal lock. Maybe it is an early version.
When I power it up all I get is the power LED and a solid green LED when it locks on signal.
Did that 2nd one show up yet, Ice? :confused:
well I heard from the guy. He sent it to the wrong person (oh nice). He said he is getting it back in a couple days and then would ship it out. He did offer to refund my money but eh I can wait.
so we'll see what happens...I think I'd be moire pissed if I didnt have a remote for the 1st one and was waiting for this one. But the universal remote works on about 99% of the menu options....there are some options that it wont work on :)
...Oh and having a universal remote that does 99% of the functions is pretty darn good! Usually those things only do the easy stuff like channels, volume & power!:)
my Radio shack 4-1 light up remote works for the menus too which is what I need it to do to program...the secret menus use other buttons that the universal doesnt have :)
Sun,Moon and Mirrors
Red lnbs , haha
