"Slim Line" or "Phase3" | SatelliteGuys.US
eeyore
5
I live in Portland Oregon. Which dish (Slimeline or Phase3) will be installed when I subscribe "the Choice package"? :confused:
Thank you!
I assume that unless you get HD you would get a Phase III dish (Unless D uses the slimline as a stock install option)
I've seen new Phase III installs here in Minneapolis
Thank you!
As said HD including your LiL HD will require the SlimLine. In my area it has seemingly become the default dish.
Thank you, all!
It seems I will get SlimLine if I subscribe HD and Phase3 if I subscribe SD only. Correct?
Which one will I get if I subscribe SD package and SD locals??
Thank you, all!
Since your locals are on 101, most likely you will only get a round (18") dish if you do NOT take HD. The only way you would most likely get a P3 dish, is if you took Spanish or Chinese prog. And, even if you do take HD prog, most likely you'll get a SL3 (as opposed to an SL5) dish, since that is what the D* HSP's are going to for most subs, as most do NOT need 110/119.
Just curious, why DO you want a P3 - again, the only thing that's really on it is Spanish or Chinese prog, but the other internationals will eventually move there as well. Other than that's, it's not going to get you anything else, except for a couple of Spanish/Chinese channels that are free with a prog package.
Thank you, all!
When I signed up for locals I got the complete HD setup , it was needed for locals.
Moving Questions
DirecTV Gurantee - CS Lied to Me!
