L615 is NOT for every 722. Mine didn't get it. It was turned off during the night, and even doing the menu_6_1_1 and then remote power-off didn't dp it either.
It's out there to all 622 and 722 receivers. That's why some of my OTA channels are pixelating, oh well let's wait for the fix to the new bug.![]()
Isn't this how the recently added feature on the Vip211s work??Direct to the EHD would be sweet but with all of the different backup devices I sure could see it being hard to get right or 100% reliable.
That is a different problem.
Yep, it was removed. I wonder if it wasn't ready to be spooled to all receivers.
This update [L6.15] have usual size ~16 MB, but spooling at slow speed - 100 Kbps; max speed is 500 Kbps for other more important SW.This seems to be a big update in file size - it took over 20 minutes to download - and now it is copying to the firmware and that is taking longer than usual as well (several minutes so far)... ah finally the reboot... allow up to 30 minutes in total...
As I said, it is still in the test phase. It was on a limited rollout targeted to areas that are experiencing the most problems. Posts here and at the other site are being monitored. Should users find the update successful, it will be spooled out to the rest of the users.
S~
I never get good results with OTA when the signal is 100. I use an attenuator to bring that down to 80 something and things look good.OK. I wasn't having any audio dropouts with my receivers but now I have pixelation with KGO (channel 7) and KNTV (channel 11) on the OTA channels even though signal is 100.
RandallA, could be overload of OTA tuner or mulipath issue. Do you have in line attenuator to check ?
Limited time offer
