HDTV and HDMI | SatelliteGuys.US
HDTV and HDMI
Not open for further replies.
bha19
54
6
usa
Any recommendations on an HDTV for under $1000. Also at my local wholesale club they have HDMI cable for $17 but my electronics superstore it is $89. What is the difference?
bha19
I won't recommend a TV, but I will tell you that if you read the other 1000 posts about HDMI cables found on these boards, you'll see that the only difference between the higher-priced cables and the lower-priced ones is exactly that: the price.
ps: $17 is about $15 too much to spend. Check monoprice.com or even Amazon.com for a better deal on cables.
:up for Monoprice. Theirs pass all the highest test standards.
You might want to tell us what TV size and type interest you.
37-47 inch and lcd or plasma does not matter
bha19
bha19
Take a look at this site it has some links to good prices for HD TV.
 HDTV News, Views & Reviews
I would not consider any thing less than a 42 inch HD TV.
This site also has some good pointers on HD TV.
Hdguru.com tells you everything you need to know about HDTV displays, high definition content, high def disc players, high definition reception and reviews on high definition products, blu-ray and
R.I.P Ron Asheton
