Thanks to some discussion with Teachsac, Im going to move my center. At our previous place, I had it mounted over the tv, but have just never done it here. I also had another tv with a smaller footprint, and this center (or any other big center) just do not match up on the stand.
I have a pc of stained shelving that came with the ent center, so it matches it perfectly, Im thinking of mounting it over the top of the tv, moving the tv forward so that the shelf edge matchs the top of the tv. Guess Ill use some L brackets that Ill paint flat black(same paint as sub base), then put a slight bend in them to angle the speaker toward the seating position. Or I could always use rubber feet and put a slight lift into the back side of the speaker.
Input appreciated, will try next weekend. Older pic, but it gives you an idea.
