I see 2 channels on 61.5, uhhhh 580 and 9902.
I see many more than that.
SatelliteGuys.US - Subscription 61.5°W
Did you recently upgrade or something? It looks like these channels are in a different channel tier. They are available out there to people with the correct tier.
Stop with the check switches. It's not going to do anything. And no, the CSR's probably do not know a thing about this channel. They usually do not until the next day. I haven't even seen a press release for this channel.
Yeah, I was at the top 100 and upgraded to the 250 gold
Just took these pics a couple of minutes ago. Keep in mind that this is off of DirecTV, not DishNet.Thank you sir
You probably received the new tier on accident that they will be sending out to the correct folks. Probably the one to keep the HD Absolute customers from seeing this channel.
If you want people to believe... take a picture with the channel information at the top showing you are tuned to the channel.
Depends on the network that you're on. Some networks will let you email the pic to yourself via a pix message.lol, I have it on my phone right now, just cant figure out how to do it.
He doesn't need the channel info. If it has the HD wing, then it is in HD. The SD channel does not have the sidebar (wing).You probably received the new tier on accident that they will be sending out to the correct folks. Probably the one to keep the HD Absolute customers from seeing this channel.
That would do it for me. And no offense to anyone, but it's easy to say that you have something. Some like to stir the pot. I spend $160/month with Dish, have AEP and Gold and plat. HD. That's why I found it hard to believe. And I didn't speak with a CSR, it was Level 5 tech support. And to confirm that, I called Matt Kliewer, executive assistant to Charlie Ergen. And yes, he actually answers his phone. The new tiers are a real possibility, I said that earlier.
Just do Edit your post and Manage attachments - get the picture uploaded here.
We cant see your picture.
Good enough for me. I stand corrected and apologize. This must be your lucky night. Maybe you should play Powerball?
All in fun jw, at the end of the day it is still only tv.
I was doing this for my sanity as well.
Well, could ya at least let me right for once?![]()
Limited time offer
