I just spent the whole day messin' around trying to upgrade a customers (2) 625 receivers to (2) 722's. I could not get the 722's to take software downloads.
1st) The check switch always came up 1 of 12 and not 1 of 3 as I usually get with a dish 1000.4. I thought that IF the Receiver see's the LNB it will give you 1 of 3? I actually replaced the LNB with no changes...took the LNB and hooked it right up to the reciever with a 6' coax whip and was hoping to see 1 of 3 on check switch...Nope...1 of 12! Is this correct?
2nd) After the check switch completed its 12 of 12 it came back with some odd results like Disqu... (sorry don't rember the name) and like 5 ports. But on the signal strength meter I can get 61.5 to lock in, and sometimes 77 to lock in...after enough tries I will get the 722 to say is everything is set and it will attempt to download initial software...it set's up and i get the bar showing the status, but it never downloads! I tried powering off the receiver and waiting...nothing!
3rd) Dish Tech Support Stinks!!!
I call up and ask for help and the stupid operator says "I don't see the 722 activated on this account. You need to activate the receiver for the software to download"
Wow...the CART is so far in front of the HORSE it isn't even funny! Is there anyone to help with tech questions? I even asked for advanced tech support and she said she was!
I am going to take the two 722's back to me shop and see if I can get them to download on my dish 1000.4 there.
Also, after pulling out the 722's I re-installed the old 625's (because I wasn't going to leave the customer with out TV) I ran a check switch and it gave me 1 of 4! It showed the birds and what was connected! This to me is an indication to me that there is something wrong with the 722's???
Any help would be great!
