So does Little Rock, AR have HD locals yet? That is much closer to me than Fort Smith so maybe I would get a better signal. What do you think?
It was posted above. Fort Smith, AR is not available yet. Keep an eye on TheList and The Uplink Center.
Right, that's why I asked about Little Rock, because Fort Smith is not yet available. I know that *D has all the local HD signals there but can't find that info for Dish.
Confused....but ok.
What are you confused about? The HD areas that I might have been able to pick up tested at such a low percentage that I was afraid I'd have trouble when it rained, etc. The ones that tested high are on 129 and have no channels on them as of yet. In the meantime, my HD locals out of Atlanta were gone because of Spotbeam and the other channels, even though on CONUS, were starting to go out at times and we'd have to change the channel for a second to get the picture back.
So........because of that, I made my billing address and physical address the same on DISH. If something comes up that includes Shreveport and I can pick up HD local networks with a strong signal, I'll move again. In the meantime, I am glad to be able to watch the networks through DISH, even in SD.
Is there a list somewhere on this site of all the spotbeam maps, or is that just on the pub side?
Mary, Dallas!!!
check your signals on 129 transponders 1-16 again. when you flip through give it time. tp5 is conus with indy HD locals which might move anyday now.
Did you see enough strength on the dallas 110 locals?
transponder 31, it should change to say spotbeam on the signal meter. You said earlier in this thread you had a signal of 28 on that beam, when I suggested Dallas, which is good enough for reception except maybe during heavy downpours.
I live in Monroe. While I enjoy my OTA HD Locals, I would like to be able to record more than one show from them in HD. I was thinking of 'moving' as well, but I get absolutely 0 on that Dallas spotbeam on 110.
Limited time offer
