I know the shortcomings of the Pansat 9200, Diamond 9000, and Coolsat 8000/8100.Vantage HD 1100s is out and has DVB S2 BLIND SCAN but has its own quirks and no 4:2:2.
Wasn't Fortec Star going to have something?Well its second quater of 2009, were are all the next generation receivers at?
What's short on the Vantage 1100?
Starman
these azbox recievers You mention
do they do 4:2:2 dvbs & dvbs2
just curious
I have a call into a Dealer too, he is also a user, so maybe I'll get a solid answer.I inquired to a dealer who was selling them with the "supports 4:2:2"....
That is High Bit Rate (around 80 and above) DVB only, not necessarily tied to Symbol Rate. TPs with a SR 29270 and more than 1 Channel play fine, stuff like ABCs HD TP does not. DVB-S2 has been fine at any Bit Rate,so far, like NBCs DVB-S2 HD TP.The High Bit rate feeds (anything above 28000 symbol rate) stutter badly when trying to play them. Other Lower Bit rate feeds play fine.
I looked at the specs and features of the HD elite and premium, and since it is running Linux, I wouldn't be suprised to find a PC motherboard inside the box with a DVB PCI card to handle the satellite channels. This would probably make it capable of 4:2:2.
Limited time offer
