Hook up | SatelliteGuys.US
Hook up
santapete
new jersey
How and where can I get a devise that will let me split a direct tv signal so I can hook up a DVR to a cable. I already have two cables coming into two receivers now. I plan to peplace one of the receivers with a DVR and need to know how to split the signal inside the house. Thanks. I am new to directv and did not get all the answers before installation.
Are you talking about a standalone DVR or a DTV DVR? If it is a DTV DVR, it should work fine with the cable you now have to the older DTV unit (You will NOT have 2 tuner operation in this manner), but other than that, it should work fine.
If you want 2 tuner operation, you will have to run another line from your antenna OR get a SWM switch (if I understand what you would like to have).
Questions about moving to D*
TBS MLB blackout
