On the EI section you need to add channel 720-1 as the HD Game Mix Channel
Remove the Strike Zone from 721-1 as the Strike Zone Channel no longer exists (MLBNet is now doing that feature).
The MLB EI HD game channels go from 721-1 through 749-1
If you don't count the RSN's and PPV, like your xls file says, the HD channel count is:Due to Dish putting up the Viacom Channels... updated again...![]()
uncrules,
Did you get the EI info I posted above?
Your Welcome, I didn't mess with the counts as uncrules said it should do it automatically.
Remove the Premiums as well and it is 56 to 55If you don't count the RSN's and PPV, like your xls file says, the HD channel count is:
DishNetwork: 78
DirecTV: 70
Good job. Now if more of those HD channels would have HD programming the claim would be even more accurate! Thanks for the update.
Done... Thanks for the reminder Hemi !Looks Like its time for an Update.:
Limited time offer
