Post Number 438 has todays update.Can we get an update after todays additions?
Yes. See the little clickable thing that says "Attached Files". right below You click on that!It does....![]()
I know how to click a link, but I would guess the yellow ones should be blue.Yes. See the little clickable thing that says "Attached Files". right below You click on that!
Here's post 438.
http://www.satelliteguys.us/1814542-post438.html
It also stands out if you only compare the basic channel (the ones most subs have).I know how to click a link, but I would guess the yellow ones should be blue.
But it is nice to see National HD 81 to 68 and D* needs to do a lot of catching up.![]()
I'll get um this afternoon when I get up if someone doesn't before hand...I know how to click a link, but I would guess the yellow ones should be blue.
I'll get um this afternoon when I get up if someone doesn't before hand...![]()
It maybe time to buy some stock in tissues.Hi,
while you're updating it, the formula's and counts on the "Regular channels" are wrong.
The formulas in cells B51,C51, F45 and G45 contain the wrong cell range and therefore the wrong counts are listed... When the Formulas are updated to ranges of B5:b50 and C5:C50 the correct Dish vs. DirecTV counts are:
Regular Channels: 44 vs 36
National HD : 84 vs. 70.
I've attached a version containing these formula corrections.
Yep...Poor Charlie finally had to do something after all of the crying over losing so many subs.It maybe time to buy some stock in tissues.
Luck D* still has sports cause they don't have anything else.Yep...Poor Charlie finally had to do something after all of the crying over losing so many subs.![]()
Anything else??? OK. Tell that to the 18 million subs.Luck D* still has sports cause they don't have anything else.![]()
Look each provider offers something the other doesn't and that suits the different needs for the different types of subs.
For me personally, Direct is the best deal in both price and channels. For the comparable package and setup with Dish I would be paying $10 more per month. Also, Direct offers more of my locals in HD (8 HD locals with Direct and 6 with Dish) and more of the channel I watch in HD.
Dish has 11 national basic HD channels not found on Direct and there are only two that I want, WGN and Travel. The others, even if they were on Direct, I would never turn to them and would not have them saved in the guide:
BET
BET Jazz
FTV
Hallmark Movies
Lifetime
Lifetime Movies
Logo
MavTV
Travel*
WGN*
WFN
Direct has 4 national basic HD channels not found on Dish:
101*
Smithosian*
Fuel
MLB*
*The only ones I am interested in and the only ones I have saved in the guide in SD and/or HD (for me personally, it is a 3 to 2 favor with Direct in basic national HD that one has that the other doesn't)
So IOW, you have nothing substantive to add?I think your post should be deleted for being a duplicate post, other then that be careful coming down from your soapbox.![]()
I can sit here and ramble on like some but the facts are the fact and they have spoken.So IOW, you have nothing substantive to add?
Limited time offer
