I bought one of those $120 shipped Fortec 90 cm dish/Merc2/HH90 packages off of Feebay last year. Not long after getting it I setup the dish and receiver in a stationary position for about 30 minutes, just to see if the Merc2 worked and to check out it's menus....worked great. I ended up selling the Merc2 to one of our forum members as I had several SD DVB receivers and didn't really need it.
Fast forward to last weekend, decided to setup the dish on the HH90 motor on a post on our back porch. I already have a .9 3ABN mounted on a DG380 on a post in the back yard, but as we all know, it is not good to let dishes and motors lay around unused.
The mounting pipe and struts are parts of 3 different mounts I had laying around, the adjustable ones on the sides came of a very nice Direcway dish mount.
The motor is (was?) distributed by Fortec, and has a Fortec sticker on it, but I believe thay are just rebadging the STAB HH90. The Fortec .9 dish is an exact match for the motor, the hole in the arm lined up perfectly to the bracket, no adaptation was required.
Took about an hour to install and plumb the mount, then about 30 minutes to install the motor and dish/hook it to CS6000-Techsat Tracker/tweak it to the arc.
I am hitting the arc very well from 72W-129W, next time I play with it I will attempt 61.5 to the east and 148 to the west.
