97w problem | SatelliteGuys.US
97w problem
kingjeste
60
4
Ohio
I got an 31in fortec dish.. Was wondering why i only get 1 TP on 97west..?
11965H only one i get..
Any idea's why? I'm in ohio..
oo forgot to mention.. also got an SG2100 motor..
yup.. i think so..
lao star us
kurdsat
rodnoy
tgn
tri-turk
vtv4
mrtv/good
aghapy-tv
cnl
the word network
al fayha
divine tv
thats what i get on 97w
Theres a lot more on there - you must be out of alignment or else you have a warped dish.
I get all the listed transponders from lyngsat with a 30" dish no problem.
My dad who lives a few miles from me -same dish- was only getting about half the transponders - some H and some V -- turns out his reflector was warped so we twisted it back into shape and voila - all the transponders come in.
King,
On that TP, what channels do you pull in?
I am skeptical as to whether you are on the righ sat or not. Knowing which channels you are receiving will help explain this.
RADAR
post 3 shows his list so he's near 97W but maybe isnt on it 100%
I would try and move the dish a little east ro west
Can you manually input few of the TPs information into the receiver and see what happen. If that doesn't work, then the receiver maybe in problem.
I got a dead receiver home and no power at all when turn on, have not has time to check it out, but will do after me come back from vacation..
I missed that post... But, I do think that he is pulling in channels from 99.0W.
AgHapy-TV is definitely from 99.0W. Some of the others I don't recognize.
Rodnoy and Divine TV I have seen before, but cannot find them now on my system or remember what sat I viewed them on before. I think they may also be from 99.0W.
RADAR
from thelist
11965 H 22000 Channel Name Video Pid Audio Pids PCR Provider Encryption Last Updated
1 Lao Star USA 7001 7002 7001 USA Siteobal N 6/02/2009
2 Kurdsat 33 34 33 USA Siteobal N 6/02/2009
3 (GloryStar) Rodnoy 4130 4131 4130 USA Siteobal N 6/02/2009
4 TGN 35 36 35 USA Siteobal N 6/02/2009
5 TGN Radio 5154 35 USA Siteobal N 6/02/2009
6 TRT-TURK 2081 20822083 2084 2081 USA Siteobal N 6/02/2009
7 VTV-4 3105 3106 3105 USA Siteobal N 6/02/2009
8 MRTV/Good Shepherd T 49 50 49 USA Siteobal N 6/02/2009
10 AGHAPY TV 1001 1002 1001 USA Siteobal N 6/02/2009
11 (GloryStar) CNL Russian 3329 3330 3329 USA Siteobal N 6/02/2009
12 (GloryStar) The Word Network 46 45 46 USA Siteobal N 6/02/2009
13 Kol Haneshama 5158 4130 USA Siteobal N 6/02/2009
14 Persian Radio 5159 5159 USA Siteobal N 6/02/2009
16 (GloryStar) Spirit 1 Radio 6133 6133 USA Siteobal N 6/02/2009
17 AL FAYHAA 202 201 202 USA Siteobal N 6/02/2009
20 Divine TV 2020 3020 2020 USA Siteobal N 6/02/2009
http://www.satelliteguys.us/thelist/index.php?page=97+Galaxy+25
from thelist
SatelliteGuys.US - 97.0°W Galaxy 19 Ku
Well, there we go! Should have gone to "The List" right off the bat! That makes it clear, all the channels that King is pulling in ARE from 97.0W.
Got to remember to consult that LIST!
RADAR
Edit by myself... correct the satellite number I referred to.
the list! here has what i get in on 97w.. used to get them all then one day gone.. didnt change anything.. but i probly need to re-tilt the dish some.. or something.. have work on that some day..
its all an puzzle to me.. getting tired of climbing the ladder... wish someone was close to me.. to check it out.. 97w & 123w are the only sats i have problems with.. some TPs that is.. 123w 11780 , 11800 are gone for me. and the sat. i set up for someone lost those TPs. i did manger to get 11800 for them but not very good only 29% when it was 50-60% .. mmm. oh, well. come june 12th alot going black.. which sux.. anyways.. i'll play around with some day.. just thought i ask.see if anyone had any other idea's.. thanks all for your input..
and btw.. i did an blind scan..detect only 1 TP on 97.. wierd.if you ask me.. i've got an captiveworks 700s box.. if i had the room i'd have an 6foot dish.. but that not happening anything soon.. i now get 101w KUIL FOX.. which is kewl.
How do you determine if a dish is warped? Obviously, if it is bad enough then you would just see it. But, what if it is warped only enough to mess things up and isn't very obvious just from looking at it? If it is warped how do you go about "twisting it back into shape" ?
Willie, if you have a glass-top dining table and lay the dish upon it, face down. that will be the easiest way to detect if the dish is warped.
To straighten it, if it is warped, you simply have to grab the dish and bend it while someone else holds it. It isn't a simple task. Requires at least two people. And of course you have to keep setting it back on the table top to check that you made a difference and did not go too far.
RADAR
the dish was not noticably warped. My dad was on the roof, I was reading signal Q from the ground. We could only get signal on certain TPs when he twisted the dish. So he twisted it into shape.
GBox V3000 Picture
