I just scored 2 free hughesnet dishes on freecycle.org !! Not sure if they have the LNB's or not will find out when I pick them up later
nice find, they work well for multi lnb setups due to the width.
Check out Linuxmans fine thread on getting the whole Ku arc with fixed dishes....
sweet
Most LNB's will work if there is one missing. The spot is usually a 25mm hole so you might have to do some "stripping" of the case on the LNB. The casing is just show and I've done that numerous times to LNB"s
Most of us know what a DirecWay dish is, but that HughesNet is less common.
Post some pictures for the gang. - :up
Use your tape measure while you're at it.
I'm just waiting for the first guy to suggest: mini-BUD! -![]()
Gotta admit something Berg. You have a way of adapting things and making them work in the environment your in. You need to win the Satellite Guys award for that.![]()
Limited time offer
