ION on 119 | SatelliteGuys.US
ION on 119
PALL MALL
114
It was mentioned in another thread that ion was on 119w, so I checked lynsat at there it was on tp14 12141L 20000. So I put up an old dish 300 and aimed it at 119 using the old dn receiver. With the dish directly connected to my fta receiver, I added the tp but no signal.:mad: I added a few other tps and they all came in. Is anyone getting ion on 119?
Yep, 79%Q (Coolsat 5000 meter) on a D500 with a DishPro LNBF
When aiming I like to use the NASA transponder since it seems weak and has a FEC of 7/8
I have 79-82%Q on NASA right now
NASA
12370 R/V 20000
ION East
12.414 L/H 20000
PID 6690
VID 6690
AID 6691
Works fine for me and I don't even know what I'm doing. :o
I hooked the dn receiver back up and tp 14 has 93% signal. So I dont know what im doing wrong. On my fta receiver I have the lbn set to stacked, should it be? My fta receiver has 99% quality on nasa but theres no pictue.
My ignorance of stacked LNBs and DN equipment is about complete, but if you have an old Dish 300 I believe that is the old legacy LNBF? Those aren't stacked are they?
turn it off stacked. Thats probably part of the issue
SINGLE 11250 LNB LO
Does the LNBF on the D300 have the DP logo on it?
If yes, then stacked with an LO of 11250/14380
if not then you might want to try setting the LO to Standard/Single and 11250
Usually when I'm aiming and I get Quality on 12370 R/V and no picture on NASA, that means I'm on 110W
The lightbulb came on.
You got NASA quality, but nothing on ION while stacked.
So set it to standard 11250, and check again. I would bet that it works now.
If you have nothing on NASA, I think you need to peak some more... just my humble opinion. :D
SINGLE 11250 LNB LO
Change the settings, and it works now. Ion scanned in :D. Thanks everyone for the input!
Now I just need a bigger multi switch to combine it with my dish at 101.
it logs Ion like 40 times :D
What Dish did is the markets where the Ion is owned by the network they just remapped either Ion East or West
All the ones that log "TV 7000-TV9000" are the local affiliates
My receiver logged them with there local call sign, I just renamed one ion and deleted the rest.
It's the first lbn in the picture legacy single output. I knew I was on the right sat the dn stb's know the difference between satellites. If I was on 110 it would have had signal but it would say wrong sat 110w or something like that.
Its to bad the old dn stb's wont tune in the fta channels anymore :mad:. I planned on setting one up in my bedroom for ion, but thats not going to happen. They'll tune in the dish fyi channel but not nasa or angel one. When I try to go to one of them, it says I need a new access card to view this channel :rolleyes:.
Motorize an 1.5M offset dish with actuator, is possible?
DG-380 motor arm position at true south
