I am also an OTA newb and I need a little help with my setup.
I live in an area where cable is not offered (it's actually about 400 yards down the road but they will not extend it) and Dish will not let me get local channels because the so called "local" stations think they will lose add revenue if they let me. I have lived without local channels for 4 years now because of this and I'm tired of it. So if I want local channels I have to get them OTA.
I live about 20 miles from most of the towers and cannot get any reception with a store bought indoor antenna. I considered buying a big OTA Antenna a couple years ago but the cost of the Antenna and mast and extra cable was going to cost me $200+. So to try and reduce the cost I made a DIY HD antenna that looks basically like 1/2 of a DB8 (4 bowties with cooling racks as reflectors and 2X4 for the spine). It's currently sitting on the floor behind the TV in my great room and when I perform a scan I can see 13 HD OTA channels. Only about 4 are watchable no signal drop (70+ signal strength) at any one time depending on where I face the antenna.
I have 2 Dish receivers that are used to connect 4 rooms; 1 VIP622 and 1 322G. Each is configured to run 2 rooms. I would like to get OTA in all 4 rooms using the existing Dish coax runs but I have read that diplexing HD with OTA doesn't work too well. If I have to run new cable for OTA I will, but if I don't have to I'd rather not. I think I will have to run a signal switch to at least the 2 rooms that don't have a physical receiver to switch between OTA and SAT.
Here are the specifics:
Zip
31808
Dish Network Hardware
Receivers: VIP622, 322G
Dish: Dish 1000.x (I'm not sure what the x is) mounted on 6 foot pole/mast in ground in back yard.
TV's
All TV's have built-in tuners.
House
Siding: Brick
Roof: 3 tab shingle, sloped on all sides.
1 Chimney: left side of house, vinyl siding
Current Dish Setup (Cable locations, connections, etc.)
Dish: 3LNB dish mounted on 6 foot pole/mast in ground in back yard toward the right side.
Cabling: 2 cables run from dish in back yard to 2 diplexers on right side of house about 40ft away. The diplexers split the 2 cables from the dish in to the 4 cables that go to each room.
I have a privacy fence around my back yard and I was thinking about installing a mast on one of the posts but now I think the chimney may be the best place for it. The only problem is the chimney is on the opposite side of the house from where the cable runs are. My house is approximately 60' long.
A relative gave me one of those rotators you can hook up that lets you rotate your antenna from inside your house. I'm not sure if I need it but I do have it.
Here are my questions:
1. Am I wasting my time with a DIY antenna?
2. Where is the best palce to mount my Antenna, whether it be store bought or DIY?
3. Can DishHD be diplexed with OTA (use the same cables)
4. If I can get OTA across the Dish cables what hardware will I need (diplexer, preamp, multiswitch, etc.)?
5. If I need to run new cables for OTA what hardware will I need (diplexer, preamp, multiswitch, etc.)?
6. A Dish installer stated that best OTA reception could be had by pointing an Antenna at an Interstate HWY that is about 4 miles away instead of toward the station towers. He claimed OTA signals bounce off the interstate and I could get better reception. It sounded bogus to me at the time but I figured I would ask the people who knew.
Any input/advice would be greatly appreciated.
Zip
31808
TV's
House
Siding: Brick
