Hello folks,
I too am having a tough time getting this bird. I've moved to a different house and am now trying to set 97 up. Here is the nitty gritty:
SV-3000 reciever (tested, worked with 97 before)
Zimwell Standard linear LNB
36" Fortec dish (brand new)
All settings confirmed, Factory reset several times
Short RG6 cable, tested working
Here is the issue:
When I select 97 as my desired sat, I seem to be getting a S: 69 and Q: 0 regardless of where I am pointed! This makes it extremely difficult to figure out if I am really pointing at a weak signal or not. Fruthermore, the dish fails to lock on to ANY satellites hence I have no idea what bird I am pointed at. Based on trial & error and following DishPointer data, I have managed to hit several birds between 74W - 110W.
Basically as soon I see the signal moving up from 69 I know I am pointing at a bird so I do a blind scan to pull in any channels possible (although it shows Q:0 in the Dish Setup screen but after blindscan I usually get decent quality but still it does not identify the bird), then Google/Lyngsat the channel names or whatever else info I can garner off them to figure what bird I am actually pointing to.
So far I have confirmed 74W (Based on Ohio News Network), 89W or 103W (based on Pentagon Channel as it is broadcast on both) and at least another 2 birds that I cannot figure out what they are. I've also hit a bird with Dish Network programming and managed to tune in to an unscrambled channel that says: Congrats! You have a Dish 500 system. (is this the 77 or 110?) All the channels came in with EchoStar prefix followed by a number: EchoStar01, EchoStar02 and so on...
So questions I really hope someone can help me with:
1- Why is my receiver not identifying the bird I am aiming at even though it sucessfully pulls channels with a blindscan?
2- Why is my signal constantly at least 69 when I choose 97W in sat lists but drops to zero when I choose anything else?
3- Is 97W to the east or to the west of 74W? (It should be to the west of course but double checking as I am running out of options)
I've spent several frustrating
evening without success, so any help would be highly appreciated.
Location is Ontario, Canada.
Here is the issue:
