Nope I can't I don't know why it just works in windows xp 32bit in windows 7 x64 I got the card detected but no signal at all basically is like I had a dummy driver that doesn't do its job.
I got it to work under windows 7 x64 that I did was to downgrade the amount of RAM so when it uses my 4 GB it simply can't tune channels but when I use 3.25GB of ram it now works, weird isn't it.
Typed msconfig start menu and click on it then go to boot tab and advanced options and put 4095 for max memory it will only use 3.25 gig
Thanks chinga69 from dvbowners forum for this tip.
The only and the last ones they ever released for this card
Twinhan Drivers for Windows 7 - DVB Owners Discussion Forum - dvbowners.com
Limited time offer
