The boycott seems to be a failure. I went online there and I had 460 friends online, about the same as always. Did anybody really think this would work anyhow?
Online doesn't mean they were playing Mafia Wars.
Ok, guys.... for those not up to levels 5 or 6 in Moscow, let me tell you about a little back-door I found..
Want to loot an executive overcoat, but not quite to the top episode in Moscow? THEN try this:
Here's what you do: Go to MOSCOW. Then Go to inventory, collections & vault (Moscow obviously). When the collections come up go to the last one, Fabrege egg collection. Right next to the collection title is should say Pakhan episode and it should be highlighted in yellow. Click it and it will take you to the first 3 jobs in episode 6. (The picture above the jobs will not be the right one for that episode though). When you click on the job to do it it may not work the first time but the picture should change to the correct picture......click on the job again and it should work.
It's going to still show that episode 6 is locked at the top (mine shows 5 & 6 locked). Just double check the name of the job 'Acquire Classified Files On Crime Syndicates'. If that's the second job that is showing then you are on episode 6. The little yellow loot indicator box next to the job should be for the overcoat.
It is confusing, but for me it still shows episode 4 on the top (as that is as far as I am), but the jobs are from episode 6. Give it a try. But don't bother with the "ask for help" job - it will not work.
IT works for episode 5 too; and nets a high powered vehicle - something Gus. I have gotten 2 of them and 6 executive coats.
Must have fixed it, because I can't click on it.
Yeah, it went away two days ago. BUT since I still have my character in that level in Moscow, I can still access the job for the executive overcoats.
I have 17 now.
How do I open this BOSS FIGHT in episode 1 Level 3. I put 4 requests up on fb & there's been no response.Can anyone enlighten me ? Thanks.
Confront Gang Leader Dmitri Leonov
Locked
Limited time offer
