2/3/2010 2:11pm - Uplink Activity Report - 73 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/3/2010 2:11pm - 73 changes
Uplink Comparison Range: 02/03/2010 01:51P - 02/03/2010 02:11P
Channel Additions:
296 - TWITR [MPEG2 SD] added to EchoStar11 110W TP 19 ConUS beam (NA)
296 - TWITR [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (NA)
550 - OLYM1 [MPEG2 SD] added to EchoStar11 110W TP 24 ConUS beam (NA)
550 - OLYM1 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (NA)
551 - OLYM2 [MPEG2 SD] added to EchoStar7 119W TP 18 ConUS beam (NA)
551 - OLYM2 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (NA)
552 - OLYM3 [MPEG2 SD] added to EchoStar7 119W TP 18 ConUS beam (NA)
552 - OLYM3 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (NA)
5306 - TMP62 [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (NA)
5306 - TMP62 [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (NA)
5308 - TMP10 [MPEG4 HD] added to Ciel-2 129W TP 23 ConUS beam (NA)
5308 - TMP10 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
5316 - TMP58 [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (NA)
5316 - TMP58 [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (NA)
5322 - TMP59 [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (NA)
5322 - TMP59 [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (NA)
5326 - TMP60 [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (NA)
5326 - TMP60 [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (NA)
5370 - TMP65 [MPEG4 HD] added to Ciel-2 129W TP 30 ConUS beam (NA)
5370 - TMP65 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
5373 - TMP15 [MPEG4 HD] added to Ciel-2 129W TP 18 ConUS beam (NA)
5373 - TMP15 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
5374 - TMP14 [MPEG4 HD] added to Ciel-2 129W TP 18 ConUS beam (NA)
5374 - TMP14 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
Channel Removals:
292 - EPIX (NA) removed from EchoStar11 110W TP 09 ConUS beam
292 - EPIX (NA) removed from Nimiq5 72.7W TP 01 ConUS beam
837 - MUN2 (A) (H) removed from EchoStar11 110W TP 11 ConUS beam
837 - MUN2 (A) (H) removed from EchoStar3 61.5W TP 27 ConUS beam
5834 - TST25 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5835 - TST26 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5866 - TST01 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5867 - TST02 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5868 - TST03 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5869 - TST04 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5870 - TST05 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5871 - TST06 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5872 - TST07 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5873 - TST08 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5874 - TST09 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5875 - TST10 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5876 - TST11 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5877 - TST12 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
Channel Package Flag Changes:
5171(5) - WTVH [MPEG4 HD] - Echostar12 61.5W TP 03 Spotbeam 3 changed to Available (H)(Syracuse, NY-CBS)
590 - MAKTV [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed package flags (A)
591 - LAMNR [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed package flags (A)
592 - ZHIVI [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
593 - RLIFE [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed package flags (A)
604 - KINOE [MPEG2 SD] - Echostar12 61.5W TP 21 ConUS beam changed package flags (A)
735 - TRACE [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
737 - KINOE [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam changed package flags (A)
738 - CTC [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
742 - ISRL1 [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
743 - GLI [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
750 - EKSHY [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed package flags (A)
752 - EURCH [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed package flags (A)
755 - BVISN [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed package flags (A)
784 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
785 - VKAIR [MPEG2 SD] - Anik F3 118.7W TP 20 ConUS beam changed package flags (A)
786 - PEOPL [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed package flags (A)
804 - NTV [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
805 - RTV [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
806 - CHNLI [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
818 - ATN [MPEG2 SD] - Anik F3 118.7W TP 19 ConUS beam changed package flags (A)
900 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
900 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
4168(168) - SPIKE [MPEG4 HD] - Ciel-2 129W TP 26 ConUS beam changed package flags (A)
4168(168) - SPIKE [MPEG4 HD] - EchoStar3 61.5W TP 27 ConUS beam changed package flags (A)
8639(33) - KCSO [MPEG2 SD] - EchoStar10 110W TP 20 Spotbeam 43 changed to Available (H)
19086 - LUDIV [DATA] - EchoStar11 110W TP 06 ConUS beam changed package flags (A)
19086 - LUDIV [DATA] - EchoStar8 77W TP 29 ConUS beam changed package flags (A)
Channel Renames:
8837(19) - WPMF - EchoStar7 119W TP 01 Spotbeam 15 renamed to WSFLD (A) (H)(Miami, FL-N/A)
Channels in the system: 6710
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
8 new HD test channels in the Dish Latino HD range. Hmmm. I guess by next week or even this Friday, we could have some new HD channels.
While you're at it, can you please add the mapdown to the HD channels in the Dish Latino HD package? :mad:
Please, oh please, tell me that is *not* "the Twitter Channel"
Could be worse... could be the TWIlight TRilogy channel :eek: (please no sparkly vampires!!)
Although, if it was some kind of weather channel interactive product... it would be much better!
As you can see...the pieces of the puzzle are being put together.
What a let down. When are we going to see more HD National Channels?
Charlie said we would see some before the next Charlie Chat & I haven't seen any. What the Heck Dish!
You could have asked me last week if we were going to have any HD channels and I would have said no. All the pieces weren't together on the puzzle yet.
I correlated the Dish Latino Max HD channel numbers with the previous uplink:
5306 = Fox Soccer Channel HD
5308 = BBC America HD
5316 = QVC HD
5322 = E! HD
5326 = Hallmark HD
5370 = Epix HD
5373 = Encore Indie HD
5374 = Encore Retro HD
Outdoor Channel HD and Tru HD seems to be unavailable for Dish Latino.
Of course, OLYM1, 2 and 3 are Winter Olympics channels.
The FSC web site link indicates that February 10th is the likely date for New HD to be made available, btw. (See threads in Dish Network Forum on FSC)
Anybody know if QVC HD is up somewhere? My mom really wants that channel.
Do you think that they will turn on these HD Channels next week?
Josh
I'm not sure about QVC HD but the new channels should be turned on between now and the next Charlie chat. SOON is getting pretty close it looks like.
I think the reason they've taken so long to turn these channels on is they want to make sure they get the bugs worked out and have very few technical diffulties as possible when these are launched.
5316 = TMP58 (same as Channel 9447) possibly a Turner or Viacom channel, hopefully TCM HD ??
5322 = E! HD
5326 = Hallmark HD
5370 = Epix HD
TMP58 is QVC-HD.
D
3/11/2010 1:07am - Uplink Activity Report - 74 changes
D
3/4/2010 12:11pm - Uplink Activity Report - 8 changes
