Just to make sure..... did you try to clear the switch matrix as RandallA suggested in post #9??
I checked the voltage. Mine said 19.6. It's a little higher that the 13-18 you were mentioning.
Is this too high?
Thanks!
Michael
Yes, but it shouldn't be the difference between getting some signal and no signal.Dishpointer says 50/90/167. Will 1 degree make a difference?
Are you checking 119W? This is necessary to take skew out of the equation.
I've found that I've had better results if I set the elevation a degree higher than recommended by DISH.
I thought I was going nuts with a problem like this until I FINALLY discovered a bad cable/connector.
I know you changed cables but are you SURE you changed out all connection points. My problem was a short cable I had coming from the LNB
The totally no-signal status means to me that your pipeline is bad.
Where do u live in So Cal.? I live in Victorville, Ca. and have a birdog meter. If you live close, I can probably help you out. PM me.Yes, I've tried 119 and 110. For some strange reason, the 211K doesn't have 129 in the Point Dish menu. It has 121 instead.
I did try going from 49 to 50 for elevation, with no luck. I'll give 51 a try, and report back.
I appreciate the ideas.
Michael
Michael
Going to suggest what may be considered stupid or obvious, but sometimes that's exactly what it is.
Did the wind storm blow something in the way of your line of sight? A tree, power lines, house?
It sounds like your mount is movable. Have you tried moving it (it being the pole and dish) to another location? ie, 10-20 ft to the right, left, forward or back.
Is the 1 output of LNBF going into the SAT IN port of the receiver, not the antenna in or tv out? (On the 211k this port is blue in color)
I know those are very obvious things, but take a minute to double check. Often it's the simple things that get ya. A few less obvious things to try.
Make sure the dialectric (the white part surrounding the stinger of the cable) is not recessed in the cable fitting. The dialectric should be flush with the bottom of the nut, with the stinger slightly protruding from the top of the nut.
Is the dish set fully on the pole? A 1000.2 has a "sag tag" in the cylinder that is supposed to set inside the pole. If you need to use a screwdriver or something to bend it out a bit, do that. Once you've done that tighten the pivot bolt (the bolt that should be resting on top of the pole) just a little more than hand tight. Perhaps 1 full turn with a socket wrench past hand tight. Then tighten the clamp bolts the same. Do this to ensure that the dish doesn't sag. If this is too tight and the dish does not easily turn on the pole, loosen them a bit. Don't overtighten the pivot bolt.
It sounds as though you have tried just about everything.
When you do a check switch, and when it is saying "doing test 1 of..." is it saying "1 of 4?" If the last number is not "4" then it isn't finding the LNBF. If the last number turns to "38" or a high number like that, then the signal is not getting to the receiver.
Check your connectors. Look closely around each stinger . If even one, tiny little sliver of shielding is touching a stinger it will short out the whole thing. No little silver strands should be near the stinger.
Is the mast truly plumb? Whatever you set your dish onto has got to be plumb...completely straight up and down.
What is your enviroment like....your surroundings?
If you still have the legacy receiver try using it to peak with. You will need to still use the 211k to power the LNB. Connect the 211k to port 2, and the legacy to port 1. Like was mentioned before 211K receivers are real buggy on the factory software when trying to lock on to a signal.
Limited time offer
