Howdy. I'm trying to set up a FTA system to hit 87W. I found an old primestar dish but the folks had burned trash in the vicinity of the dish and I think the LNB toasted.
The dish itself looks fine, no cracks or anything so took it and picked up a different LNB. This universal one to be exact.
Heavy Duty LNBF
I also bought the Maxpeak meter to try to tune all of this in. Now, I can't find *anything*, anywhere. I still have an old DTV dish up on the roof, so I hooked up the meter to that, and it finds two DTV birds, so I know the meter works okay. Since this is a universal, I have to switch the 22khz on to make the LO go high. What I don't know is if the Maxpeak does that automatically. Can't find anything in the booklet that came with the meter.
After messing with this for several hours this afternoon, I hooked up the P dish to an old DTV receiver, yet still couldn't get a signal to be found. Not sure if the DTV automatically does the tone, either, though.
Anyone have an idea how I can utilize this meter with this lnb? I bought the LNB awhile back before I found the dish, and I guess now I should have picked up a standard instead of universal. Here are a few pics I took today, as I'm also not sure just how accurate the elevation marks are now that I changed the LNB. This new one doesn't fit exactly like the old one did, it now lies closer in towards the dish. Hopefully that won't throw things off too badly.
I have the dish elevation set real close to 50 here,
and then I was checking it with my incl to see how close the scale is. I've never touched a P dish before, so should I be reading it like this
or should I make the actual arm be my gauge?
I appreciate any input you guys have.
Heavy Duty LNBF
