222k pixels, signal loss? | SatelliteGuys.US
K_dgoodwin
10
north carolina
I have two separate people with the same model receiver and the same problem. First person has a 222k. TV 1 will have pixelization only on locals. Check signal strength and it is fine. Then if you reset the receiver tv1 works fine and tv2 has pixelization. Second person has 2 - 222k receivers, 1 receiver is working fine and the other receiver which is a 222k has pixelization only on tv 1 and on a few of the higher channels (132, 198, 131). I switched the receiver to a different room with different cable and the same receiver did the same thing. Help!
It was perfect for 6 months...
My 222k tv1 is having trouble.... tv2 is fine....
They are both connected via coax to SD TVs. Problem on local channels provided by Dish, (no OTA).
After reset it works fine for a while, but it has happened before.
TV1 screen freezes and/or goes black, audio continues like nothing is going on...
:confused:
Possible to use a GBOX
Question about 922 upgrade problems
