6/9/2010 3:25pm - Uplink Activity Report - 55 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/9/2010 3:25pm - 55 changes
Uplink Comparison Range: 06/09/2010 03:04P - 06/09/2010 03:24P
Channel Additions:
7738(19) - WUNM [MPEG2 SD] added to EchoStar10 110W TP 31 Spotbeam 05 (NA)(Jacksonville, NC-PBS)
7738(19) - WUNM [MPEG4 SD] added to Echostar12 61.5W TP 03 Spotbeam 5 (NA)(Jacksonville, NC-PBS)
8663(17) - WUNE [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam A17 (NA)(Linville, NC-PBS)
8663(17) - WUNE [MPEG4 SD] added to Echostar12 61.5W TP 11 Spotbeam 8 (NA)(Linville, NC-PBS)
8763(36) - WUNP [MPEG2 SD] added to EchoStar10 110W TP 31 Spotbeam 05 (NA)(Roanoke Rapids, NC-PBS)
8763(36) - WUNP [MPEG4 SD] added to Echostar12 61.5W TP 03 Spotbeam 5 (NA)(Roanoke Rapids, NC-PBS)
286 - TWITR [MPEG2 SD] added to EchoStar11 110W TP 19 ConUS beam (NA)
286 - TWITR [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (NA)
287 - EARTH [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (A)(Dish Earth-Live video from 110° Satellite)
287 - EARTH [MPEG4 SD] added to Nimiq5 72.7W TP 15 ConUS beam (A)(Dish Earth-Live video from 110° Satellite)
289 - REELZ [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (A)(Reelz Channel)
289 - REELZ [MPEG4 SD] added to Nimiq5 72.7W TP 07 ConUS beam (A)(Reelz Channel)
395 - SMC [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (A)(The Sportsman's Channel)
395 - SMC [MPEG4 SD] added to Nimiq5 72.7W TP 09 ConUS beam (A)(The Sportsman's Channel)
396 - OTDCH [MPEG2 SD] added to EchoStar14 119W TP 20 ConUS beam (A)(The Outdoor Channel)
396 - OTDCH [MPEG4 SD] added to Nimiq5 72.7W TP 05 ConUS beam (A)(The Outdoor Channel)
578 - TARAM [MPEG2 SD] added to Anik F3 118.7W TP 14 ConUS beam (NA)
9528(273) - GLVSN [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (A)(Galavisión (Este))
9528(273) - GLVSN [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (A)(Galavisión (Este))
19080 - MUNDL [DATA] added to EchoStar11 110W TP 01 ConUS beam (A)
19080 - MUNDL [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
19212 - OTST8 [DATA] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
Channel Removals:
296 - TWITR (NA) [MPEG2 SD] removed from EchoStar11 110W TP 19 ConUS beam
296 - TWITR (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 31 ConUS beam
4933 - CI (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Crime & Investigation Network HD)
4935 - GREEN (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Planet Green)
9448 - TMP63 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam
9448 - TMP63 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 03 ConUS beam
19211 - OTST7 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
19213 - OTST6 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
19217 - OTST5 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
Channel Moves:
9710 - 3ABN [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)(3 Angels Broadcasting Network)
9710 - 3ABN [MPEG2 SD] moved from EchoStar6 61.5W TP 04 ConUS beam to EchoStar3 61.5W TP 25 ConUS beam (A)(3 Angels Broadcasting Network)
Channel Package Flag Changes:
653 - AFR24 [MPEG2 SD] - Anik F3 118.7W TP 25 ConUS beam changed to free preview (A)
667 - AFRMU [MPEG2 SD] - Anik F3 118.7W TP 14 ConUS beam changed to free preview (A)
751 - AFROM [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed to free preview (A)(Afrotainment)
826 - MDIAL [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam changed to Available
826 - MDIAL [MPEG4 SD] - Nimiq5 72.7W TP 31 ConUS beam changed to Available
Channel Mapdown Changes:
5347 - UNVSN Ciel-2 129W TP 32 ConUS beam mapdown of 59 added (A) (H)(Univisión (Este))
5347 - UNVSN Nimiq5 72.7W TP 06 ConUS beam mapdown of 59 added (A) (H)(Univisión (Este))
5348 - FTRAW Ciel-2 129W TP 32 ConUS beam mapdown of 63 added (A) (H)(Telefutura (Oeste))
5348 - FTRAW Nimiq5 72.7W TP 06 ConUS beam mapdown of 63 added (A) (H)(Telefutura (Oeste))
5562 - SMC EchoStar10 110W TP 12 Spotbeam 46/47 mapdown changed from 285 to 395 (A) (H)(The Sportsman's Channel)
9483 - SMC Ciel-2 129W TP 20 ConUS beam mapdown changed from 285 to 395 (A)(The Sportsman's Channel)
9483 - SMC Nimiq5 72.7W TP 03 ConUS beam mapdown changed from 285 to 395 (A)(The Sportsman's Channel)
Channel Renames:
6671(3) - WREG(Memphis, TN-CBS) - EchoStar10 110W TP 25 Spotbeam 14 renamed to KFVS(12) (Cape Girardeau, MO-CBS) (A) (H)
6672(5) - WMC(Memphis, TN-NBC) - EchoStar10 110W TP 25 Spotbeam 14 renamed to WPSD(6) (Paducah, KY-NBC) (A) (H)
4137 - TMP13 - Ciel-2 129W TP 26 ConUS beam renamed to TMP?? (NA)
4137 - TMP13 - Nimiq5 72.7W TP 32 ConUS beam renamed to TMP?? (NA)
4277 - TMP63 - Ciel-2 129W TP 20 ConUS beam renamed to GLVSN(273) (A) (H)
4277 - TMP63 - Nimiq5 72.7W TP 03 ConUS beam renamed to GLVSN(273) (A) (H)
5316 - TMP13 - Ciel-2 129W TP 26 ConUS beam renamed to TMP?? (NA)
5316 - TMP13 - Nimiq5 72.7W TP 32 ConUS beam renamed to TMP?? (NA)
5349 - TMP63 - Ciel-2 129W TP 20 ConUS beam renamed to GLVSN(65) (A) (H)
5349 - TMP63 - Nimiq5 72.7W TP 03 ConUS beam renamed to GLVSN(65) (A) (H)
Channels in the system: 7350
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.06.01
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Ok here are some things...
Dish Earth is moving AGAIN from 295 > 287
Reelz Channel is moving from 295 > 287
Interesting one is Outdoor Channel on 396 in the HD range... while not uplinked (but was a few weeks ago) could we soon see Outdoor Channel HD? Its the only channel in that range without and HD channel.
Looks like Twitter TV could launch soon. I just took a look at it, and see it's advertising the new DISHsupport.COM website. :D :D :D
I took a look at 4137 and 5316 which is listed at TMP13 and TMP?? respectively. Both are showing QVC HD... this one could be launching soon as well.
An interesting uplink... just trying to read the tea leaves and see where we are headed in the future. :)
finally they added galavision... really excited for this channel. What is up with the movements of the Outdoor Channel and SMC to the 300's?
Si, Señor.
Seems like this move may have fixed the authorization issues for 3ABN on 9393, whatever that was.
D
6/7/2010 6:25am - Uplink Activity Report - 4 changes
D
6/10/2010 7:27am - Uplink Activity Report - 13 changes
