C band newbie | SatelliteGuys.US
C band newbie
jge
13
mexico
Hello
I have two small fixed dishes (not motorized)
for getting some Ku band channels.
I am using a 4X1 diseqc switch to connect those Ku band lnbs
to my viewsat VSMAXHD.
I am adding a bigger dish for some C band channels.
The question I have is regarding switches.
Can I use the same diseqc I already have for connecting the
new C band system?
In other words, Can I connect the C band lnb to the existing
switch that I already have for the two Ku band lnbs??
I am pretty much sure that this is a basic question.
Sorry I could not find that info in the forums.
Any link/answer would be really appreciated
yes you can, once there is a port for it. . .i also have 2 ku dishes and a bud with a c/ku lnb on there and i use all the ports on my 4x1 switch, just remember which lnb is connected to which port.
additional consideration:
Curious what feedhorn / LNB setup you have on the C-band dish.
If it's a co-rotor style, you'll need some way to select between Vertical and Horizontal.
However if it has (or you install) a modern voltage-controlled LNBF on your BUD, then it'll work right through the diseqc switch seamlessly. ;)
im not sure if the question was directed at me, but i will answer. . . :)
i have a chaparrel wideband feed with servo. . .i control the servo via one of two of my pansat receivers or my 4d
and thats seamless imho.
I wanna thank greenguy for providing that
helpful answer.
Anole:
This info is on the brand-new LNB I bought:
Input freq 3.4-4.2 GHz
Output freq 950-1750 MHz
LO Freq 5150 MHz
Gain 70db
Noise Figure 13K
Not sure, I guess it is a modern voltage-controlled LNBF.
Am I wrong?
Thank you
can you take a pic of the lnb or maybe post a link to one like it?
i dont know if the guys will be able to tell what you hav by the info you posted. . .i know its a c band lnb and thats it.
Greenguy
Sorry for the delay.
I am attaching the picture of my lnb
thanks again
I just read the label.
It says, WSI DMX241.
If you'd mentioned that, we'd recognized it right off! ;)
Sounds like you're all set. - :up
Just hook up your C-band LNBF like any Ku device.
See this thread for help, but feel free to ask for clarification if ya like.
Switch setups simplified
How often do you have to re-align your BUD
Satmex 6c @ 113 4DTV Sat designation Table
