Ohio News Net. move again? | SatelliteGuys.US
I was watching the sports news/review last night and poof! No Signal!!! Rescand................nothing!:(
interesting that right now (11:00 CDT) there is a feed at 11744 which is too close to 11747 (if it was active)
maybe they're moving (again)
no
and its not ONN...its that Channel 12 from Connecticut or the Northeast...they show up on 74W all the time
The feed is gone right now...the one I posted above
There are a couple other HD feeds on that satellite which will give you green lines unless you have a HD receiver
The BLSA shows a signal at 11734 H 3918.
I can't lock it.
It's possible that it's DVB-S2 and I just have a weak signal or it may be DVB-S 8psk Trellis.
There was a post over at the SNG (private forum) that ONN is leaving satellite and using the internet to distribute it's signal, seems the post might of been accurate :(
OUCH
That would suck, been ONN-watcher all the time I've had digital receivers!
I watch ONN quite a bit... my favorite segment is when they rebroadcast newscasts from local stations around the state...
Hope this doesn't become a trend with other FTA channels. Ku-Band is not considered by many broadcasters to be a reliable transmission means, and fiber/IP is becoming more easily available.
fox's satellite on the simpsons
sathawk help
