Actuator Good or Bad?? | SatelliteGuys.US
carlospr43
967
12
US
Hi,
Just getting ready to install my 10' Bud. I have reconditioned , painted, new screws etc most of the parts. Just wondering if is any way I can test the actuator before going to the roof to do the installation???? Any help will be appreciated!! Thanks :up
Hi,
What kind of roof install did you do? What kind of roof do you have? Can you please attach some pics? Thanks.
You can connect the two heavy power leads to a car battery. It will run on 12v, just slower. Reverse connection will run actuator other direction.
Confusion With Sats @ 43w and 45w
Unreliable Sources
