Would a 120 GB hard drive be ok for use on the AZ Box? 300 GB or 500 GB?
Nothing is mentioned in the manual about this.
Thank you. I have been thinking about using a 500 GB internal hard drive. I figured the 160 GB may be too small. I want to record some shows and short videos.
Thanks everybody.
hello gentlemen
I recently installed a Western digital 1T hard drive on my AZBOX+ the box recognized the drive, I formatted without the deleting any partition, after the drive was formatted it shows Linux p1 964 gb, I preceded to record a part of the
movie they did record it and play it back with no problems, I recorded 3 small portions of different shows, now I try play back these three shows I get an error
" not supported " any it doesn't play the file. I was thinking maybe I should delete the partition it reformat the drive again.
I hope I'm not kidnapped in this thread, if I am, I really want to apologize.
Any thoughts will be much appreciated.
Thanks in advance.
Regards.
Chewie
MrFTAMan,
I think you would be correct in assuming that a 160 GB HDD would be too small. In all honesty, when you start collecting videos and movies and favorite shows, they do start to add up fast. I would personally not use anything less than 500 GB but would also steer away from anything larger than 1 TB (until it is proven) that such a large or larger HDD is fully compatible with the AZBox.
One external HDD that I have also used is the 750 GB Maxtor One-Touch. This being an external USB connected drive. This is very convenient as you can format it to be compatible with your PC and thus can use it in conjunction with either the AZBox or your PC and it is easily disconnected and connected to one or the other.
RADAR
MrFTAMan found something on page 12 of the Elite/Premium Manual:
"The large storage capacity of the hard disk drive allows you to record up to about 60 hours of television-in case of 250 gigabytes-in excellent picture and sound quality."
From the above can we assume that a HDD of 500 GB = 120 Hrs of TV recording, and 1 TB = 240 Hours of TV recording??
I just ordered a Maxtor 500GB internal HDD on Ebay!
Thank you guys for all your input!!!
Chewie,
How did you record these programs and how are you attempting to replay them? If you set a timer for record (reserve record) or if you just hit the RECORD button while a program was in process, then you should try to replay it by pressing the MENU button (to the upper left of the OK button) and scroll down to the RECORDED PROGRAM option and use the CHECK button (to the upper right of the OK button) to select the program to replay and then press OK.
If that is what you have already been doing and it results in the error you mentioned, then I might tend to agree with others who have reported problems with Western Digital HDDs having compatibility troubles with the AZBox. I have read others stating such before, so I wouldn't be surprised, although I wouldn't be able to explain why.
It seems that we usually hear about the failures much more often than we hear about the successes. My best luck (without any troubles) has been with the "green" HDDs from Samsung (HD103SI model for the 1 TB size internal drive).
RADAR
I hope I'm not "bursting your bubble" but I found a WD 500GB at Staples for less money than a 250 GB at ebay.
hello gentlemen
Thanks in advance.
Regards.
Chewie
I get the same error but when I transfer the files to my laptop the programs playback but I got an "invalid pixel format" error even though the video played fine on the laptop. The timeshift feature works great though. I have a WD 500GB in the Ultra. It sucks to still be without a decent PVR. Oh yeah, I have an external USB attached WD 500 GB HD attached to my Elite and I get the same results. 5020 firmware on both boxes.
Yikes, guys does this mean that WD is not compatable withAzbox? I was going to pick one up next week, but maybe now I'll wait a bit. The other option was the Seagate, don't think the local outlet I have here carries the Maxtor that FTA Man is ordering. Maybe look for Samsung?
Limited time offer
