Having a hard time setting SWM dishes with a Birdog 4, always get reds on 103 and 99. Had a good installer try, same kind of Birdog, still reds. What are we doing worng?
If you are using the SWM LNB to point the dish you will fight all day long to get it aimed. Use the SL3 or SL5 lnb to aim, then change it out for your SWM lnb.
What's the difference between aiming a swm sl3 or sl5 lnb and an sl3 or sl5 non swm?
Totally different in the way the two operate. The older SL3/5 LNB's are much easier to point the dish with.
I often use the legacy LNB to aim the dish, then just change it out and put in the SWM LNB. Directv does not like this procedure but it works very well. Just don't do a lot of bumping the dish while changing the LNB. My signal strengths using the swap out method often gets me just as good or better signal levels than doing the alignment using the SWM LNB. I have older Birddog meters that do not power the SWM LNB and setting up to align the dish using a SWM and 2 port switch takes a bit longer than just doing a quick change out after aligning with legacy.
Part of the reason you may be getting the red X is the reflector may be bent, or somehow out of alignment and the full signal is not being reflected to the LNB. If you can get another dish, align it and see if the red X goes away.
Either method will work. I'm inclined to agree with Rauol in that mast may not be plumb. Some will use a torpedo level to do so-I prefer a post level that can be viewed in vertical and horizontal planes simultaneously. Not following established procedure for dithering will result in less than optimum dish settings. Signal level meters will read the same values over a fairly wide window of placement. Dish has to be centered in the window
I may be a little more vertically challenged than most. LOL
Limited time offer
