What's the difference in channels in the 200 range versus channels in the 9000 range? I have both listed in my guide. I suspect it is different satellites, and if so are there differences in quality? Thanks!
It's all the same. The 9000s are simply shown as 200s to keep everything in a smaller place.
teneightyp said:Then why not eliminate the 9000's and just list the 200's?
Because they cannot "use" a number twice but they can map the 9000 number to the lower range.
It is to put the HD version channel number next to the SD version channel number.
Let's look at it this way.....
ESPN is on channel 140
ESPN-HD is also on channel 140
The only way that can be done is to map down the HD channel from another channel number. Remember Dish has, literally, thousands of channels when you take in the local in locals. What they are doing makes total sense if you keep that in mind.
Or, on the HD receivers they could have an option...Hide SD duplicates.
The only option I've seen for HD preference is for locals. Is there one to hide all SD dups??and they do, show HD channels only. Just click menu until you get to HD channels......
The 922 has the option to autohide all the SD versions if there is an HD channel.
Limited time offer
