Why should I use a swm 8 switch that requires 4 lines when I could use a swm 8 splitter with only 1 line?
I have used a swm 8 switch with the swm 4 expander, but is this the only thing a swm 8 switch should be used for?
No. You would need to replace the SWM LNB with a standard LNB and then feed the four outputs to the SWM16.Question I have a SWM LNBF on my Dish, if I want to have more than 8 tuners with my installation can I just get a SWM 16 switch and connect it to my Single Feed from my SWM LNBF to support 16 tuners?
John
My first job solo was a 9 out with a SWM 16......yikes
Limited time offer
