I'm surprised anyone is still on about this.
Sooner or later, everyone will realize that "HD-Lite" doesn't exist; it's just a made-up, pejorative term to describe a valid HD format.
I'm glad to even have HD-lite, looks better than the crappy SD only i could get from Suddenlink Cable.![]()
Well it is more than that. It is when they take something from a programming provider that is in 1920x1080 and down convert it to, yes, a valid format of 1440x1080 to help it not look so bad when they extra compress it. There are still some providers that do not apply extra compression to HD channels like FIOS. Unfortunately both DBS companies and now a lot of cable companies are doing this.
Have any proof of that? My local CBS does no multi-casting and I have no reason to believe it or any other of my local 1080i channels are not full resolution. They also all are better than the same channel provided by Dish.OTA definitely is not full 1920x1080, especially if it is 1280x720.
Upconverting does not give you a better picture, you can't create resolution from information that isn't there.As far as having a 1080p TV, you will get a better picture irregardless of the source as it is upconverting to 1920x1080p.
Dish can only be as good as the networks are providing them and I don't believe any of them are providing full 1920x1080 anymore. OTA definitely is not full 1920x1080, especially if it is 1280x720.
When I used OTA I thought they were broadcasting in 720P? But still HD over OTA looks way better than overly compressed satellite HD from what I remember. And Blu Ray should be the standard that the satellite companys should be shooting for, but next pipe dream please! I have seen movies on D* HD that I have on Blu Ray and the Blu Ray blows away the satellite picture by far, and lets not forget how much better the lossless sound is on Blu Ray to just plain ol' DD! And you are correct about upconversion, it has it's qualities, but you can't upconvert 480i (DVD) to 1080P.
Jeff
You're using a 10 year old post based on 15+ year old report to prove your point? You do realize technology changes, right? Also, when talking about OTA, just because a network (NBC, CBS, ABC, FOX) puts out a certain resolution, doesn't mean the station is putting out that resolution. Our CBS local takes the 1080i from network and converts it to 720p to add subchannels.Primetimeguy,
Then why don't they look like Blu-Ray? Because the resolution isn't full 1920x1080. See this- FCC's experts report these color/B&W resolutions for HDTV programming - AVS Forum Archive and maybe a lot of 1440x1080 cameras are still being used. Theoretically Dish could be sending a better signal than OTA, some programs look it to me.
Tell that to everyone who bought an upconverting DVD player (me included) and yes you can there IS information there to extrapolate from.
If you don't want to believe everything looks better on a 1080p set than on a 720p set , then I assume you own a 720p set.
Limited time offer
