For a single H24 receiver installation, can I use a deactivated H21 to power the LNB or do I need to get the power inserter? If I can use the H21, how do i set it up?
A receiver isn't capable of the voltage (21VDC) or current required to power an SWM LNB.
DIRECTV will likely want their H21 back if you didn't buy it outright from DIRECTV.
It is implied by the question.He didn't say he had a SWM lnb.
If you ask if a receiver will work as a power inserter, it is implied that you need one.It was, how so?![]()
not necessarily. He was asking a simple question.If you ask if a receiver will work as a power inserter, it is implied that you need one.
It doesn't seem reasonable to assume that if the H21 worked, that the H24 wouldn't work in its place.
self-installing is overrated.
Really? How so? Where was SWM ever mentioned by the OP?
I guess I don't have a SWM LNB because the only receiver I had before was the H21 and there is no power inserter.
Limited time offer
