Was it actually a 722k receiver?... and replaced the 625 receiver with the vip722 receiver. ...
You said it came with a learning remote. I'm sure I'm confused, but I thought the 722k was the one with a learning remote.It wasn't a 722k. Just a regular 722... I did ask if he had the 722k but all he had was 2 722's in his truck. ...
MattG@ DISH NETWORK said:Your account is probably tagged wrong if you're still getting calls. I can fix it in just a few seconds if you'd like (just PM a phone/account number)
If you never received any calls or letters, chances are your account was probably tagged wrong. The reason we made the virtual channel moves is so that we can get customers (like yourself) to call in to get a migration done.
If there's anything you want me to review, feel free to PM account info.
I'm in Maryland & I keep getting calls about needing to upgrade. I have the VIP622 & the Satellites are 119, 110 & 61.5. Do I really need to upgrade? Most of my HD channels moved to the 4000's. I don't seem to be missing any channels. No one is home during the hours that they would need to come out, so if I don't need to upgrade I don't want to. Any help would be greatly appreciated.
Thanks. Will I also need to upgrade my receiver? It's the VIP622.
Hi, the technician would normally do an inspection of the entire system. If all the wiring in your home is good then he would not need to change anything at the receiver itself. We do recommend that the upgrade be done as soon as possible but a after your vacation should be fine. Have a great time and we will get this completed for you when you return!Got another stupid question. Would the technician need to do anything with the connection to my receiver or would they just need to change out the two dishes for one? The reason I ask is that my entertainment center is very large & heavy & cannot be moved so it's gonna be a pain if they have to do something to the connections to it. Plus, I just have these small holes that the cables fit through. You'd have to see it. The last guy that came out when I got my new DVR had a fit. Also, when does this all need to be done by. I am going on vacation for a few weeks.
Limited time offer
