You can manually set each recording to begin or end before or after the default guide setting.
I can begin early but please tell me how to end early. D* DVRS do not have that option..only to end late.
If they are the same network it will overlap just fine and record both shows on same tuner. I do it all the time
Right. But if they are not, it won't. I guess the real question is why is this simple option not available?
You have been told twice that the only way to do it is a manual recording. What don't you understand about that? There is no other option at this time. Perhaps you could send a suggestion to Directv about it.
Limited time offer
